Alkali Fatahu
Alright! I will do that now and get back to you.Pull the injectors with the fuel rail and turn on key. Fuel should spray out (obviously a major FIRE HAZARD) if it does work/spray. Do so safely...
If it does, you'll need to check fuel pressure while assembled.
We're trying to determine if the rail/injectors are clean, it's possible the injectors are NOT opening-IE electrical issue..
