Alkali Fatahu
Yeah I did
That looks like a nylon automotive type plug but what is inserted in it? Can you give the color of the wires attached to it? Example White with red tracer or green with a black tracer...There is another issue. After boxing the engine the first time, there was a code that had to do with abnormal voltage supply to the FI system. I troubleshooted and found the problem to be the component attached .
Attached is what is inserted in it:That looks like a nylon automotive type plug but what is inserted in it? Can you give the color of the wires attached to it? Example White with red tracer or green with a black tracer...
LOL, more questions than answers. Is that the connector holder, or was that what it was connected to?
The link is inserted into the socket and, I think, this ensures power is distributed to the outgoing wires.LOL, more questions than answers. Is that the connector holder, or was that what it was connected to?
The wires are six. Each is black with green dot.
One of them goes to the radiator fan, one to the fuel pump power socket, one to the the fuel pump level indicator, one to the kill switch. I did not finish checking on the remaining two.
The picture I attached, I think, is like a link.
I have just read your suggestion. Actually, I have disconnected the horn because I want the bike extremely naked. I will do as you have suggested and report back.
