2008 FZ6 having problems starting
Ivas231
I just purchased a 2008 fz6. It was running great with no problems for about a year. The other day I went to start the bike and I made the terrible mistake of hitting the start button before the ignition start sequence was finished (the fuel pump priming and the gauge cluster dance). The button was pressed down and the starter was not going. It wasn't even trying. The bike totally lost power as soon as the button was pressed. Naturally I check the fuses. They were all good. The bike was able to run after I bump started it but the starter does not work. Anytime I turn the ignition on and hit the start button, the cluster will loose power. When I go to turn the ignition on and off, only the neutral indicator is on and the bikes turn signals pulse very faintly and I hear a clicking noise clicking from the relay assembly (Part Number: 5VK-81950-30-00 5VK-81950-31-00). Please help!
