4 pin relay
Japarley
uk
Hi everyone, while i was having new tires fitted (both wheels of bike )
it fell on it left hand side NO DAMAGE done ,
whilst checking i noticed a relay had a top pice broken
these are under the cover left sde, on partzilla electrical 2 its part 24
iv looked at the manual and its a 4 pin but no number?
but in (pz) its listed as a 5EA-81950-20-00
any ideas as to what it does ?
found lots on Ebay
Mind you...this is based off a US FSM and US parts fisch, but part number 24 points to the center relay. Looks like it could be the fan motor relay. The one to the left of it is the turn signal realy and the one to the right is the dimmer relay.
trepetti
It's all good!
Northern New Joizey
found lots on Ebay
There are 2 4-pin relays in the left pod, one for the headlights and the other for the cooling fan. So assuming that the headlights are working normally, pull the relay, start the bike and if the headlights work then it's the fan relay.
Japarley
uk
Hi thanks for your replys, due to this virus iv disconnected the battery and bought it
back indoors (to stop it being stolen ) garage a long way from house ...!
disc locked and chained through back wheel ...!!! so should be safe ?
the dimmer relay is to the right and has 16 pins
the lighting was OK as was the starting and fuel pump
but bikes fan has never been on to my knowledge ?
the bike is running great it was just recently i did full filter change oil / air
and noticed a petrol smell id never smelt before after a 30 mile run
then finding this damaged relay thought it might be because of it
ill replace it anyway
Thanks
The dimming relay does not have 16 pins, thats the immobilizer. If the fan didn’t run you’d know it. While the fan runs smooth and quiet, when they don’t work the bike will overheat at a stop light.
Fan relay has wire colors:
Brown with black tracer
Red with white tracer
Blue
Green with yellow tracer
Headlight relay wire colors:
Red with yellow tracer
Green
Yellow with black tracer
The bike should not over heat at short stopping times. The FZ6 runs very efficiently as for as cooling goes.
The 16 pin assembly in that part of the bike is the starter circuit cut out relay assembly that takes care of safety protocol regarding side stand and in gear starting etc.
Japarley
uk
Hi Cris just had a shifty on the net and the 16 pin relay on my bike
has something to do with the fueling side ?
part number 5px-81950-00
Yamaha FZ-6 Fazer RJ07 04-06 5PX-81950-00 relay fuel pump 314-067
5px-81950-00
Yes that 16 pin assembly (all 16 pins are not used) is a starter interrupt/cut off relay assembly. It contains diodes and 2 relays. 1 relay (internal)that runs the fuel pump and 1 relay (internal) that interrupts the passage of current to the main starter relay. It looks at the neutral safety switch, side stand switch and clutch lever switch. to logically look at those switches and interrupt the starter from operating if the bike is in gear with out the clutch lever being pulled in, or it sees the the bike is in neutral before allowing the starter to operate. The other relay is controlled by the ECU and turns off the fuel pump if the bike is put in gear with the side stand in the down position etc. Basically a safety interrupt relay assembly.
Japarley
uk
Hi everyone update on this relay it's a
5EA-81950-20 4 Pin Relay
situated next to that 16 pin one,still not sure what it does ?
but found replacement on Evilbay 2 for £9.99 +99p post band new...!
so now have a spare :)
There are 2 identical relays. Below are the wire color codes as depicted in #6 post.
Blue
Green
The 16 pin module is the Starter interrupt-Cut off Relay assembly.
Also this thread will help. https://www.600riders.com/threads/no-neutral-light-and-no-current-from-starter-switch.59609/
Japarley
uk
Cheers Clif well it looks like i have a spare one now...!
can't leave the house to check color wires at the moment locked down
im working on another project in the shed
