chlowen
Hi,
I've had my FZ6 since Sept 2018, I have come to love this bikes handling and power, one thing that was bothering me was the throttle's abruptness at low speeds and also when cutting the throttle off in a corner and then back on which results in a bit of a surge, very unsettling in tight fast corners. I did a lot of research and weighed up the costs of potential fixes(Powercomander, ECU Refresh, Throttle tamer, TPS alignment, BoosterPlug, Chain tension, throttle slack) My bike has good chain and throttle cable tension, so i knew it wasn't either of the free fixes, I wasn't sold on the throttle tamer as I ride a KTM 300 so I know how to use my right hand on a throttle. I read all the information available about the BoosterPlug before I purchased, it is quite a simple device but it did look promising, it took 5 minutes to fit. My bike is now smooth off the line from a standstill, it is smooth when chopping the throttle at speed or in a corner(important one for me), I am very happy with how my bike now handles it's fuel injection.
The boosterplug simply tricks the ECU into thinking the ambient temp is 20 deg Celsius lower than what it really is, so the ECU adds more fuel to the bike, but it only does this when the throttle is being moved, it doesn't do it when you are cruising.
The BoosterPlug E Book on ECU fuel injection explains how our fuel injection works in open and closed circuit modes, open is when the throttle is being twisted so the ECU reads the ambient temp via the Air Temp sensor(BoosterPlug - 20deg more fuel to smooth things out)
When you are cruising and the throttle is stationary the ECU is now in closed mode and uses the O2 sensor in the exhaust(Not the Air Temp Sensor) to measure how much fuel is needed by reading the amount of unburned oxygen, therefore the BoosterPlug isn't telling the ECU to use more fuel when in closed mode.
It is a super simple device that is quite clever. I hope this review is helpful to some.
Regards,
Paul.
Regards,
Paul.
