FIZZER6
The Angry Blue Mantis
Why spend $100-$150 for a piece of equipment that can be built for $20 in parts and an hour?
BUILD YOUR OWN MANOMETER FOR THROTTLE BODY SYNCHRONIZATION! :rockon:
I saw a few pictures on other bike forums of a couple homemade manometers, realized how simple it really was and successfully attempted it myself. You can too!
To Build the Manometer you will need:
Qt. Part # / Description
(4) Dorman 47311 Vacuum restrictors (3/16") - I found these at www.rockauto.com and most autopart stores carry these as well.
(2) Dorman 47356 Vacuum "F" connectors (3/16") - I found these at http://rockauto.com/dbphp/prt,42,47356
25' 1/4" O.D. x 0.17" I.D. clear vinyl tubing
(1) 1"x4"x24" clean board (for mounting the assembly to)
(16) zip-ties (4" long should be adequate)
(1) Hook/hanger to hang the assembly vertically
Tools needed:
Drill
Scissors
Marker
Straight edge
CONSTRUCTION:
1. Lay out your 1"x4" board and draw a series of lines across it using the straight edge...they need to be as square as possible with the base of the board...I recommend using a builder's square to create the lines. 1/2" apart should be ideal although as you will find later...the lines don't help much because you don't need much precision!
2. Use a 3/4" piece of the hose to connect the 2 "F" connectors into a 4-point manifold
3. Cut your hose into 4-equal length sections around 6' in length each. Attach 3 of the hoses to the manifold, leaving one of the end hoses off for now
4. Lay the manifold on the board and mark spots on either side of the center portion that you will drill in order to fasten the manifold with zip-ties.
You will want the hoses to run straight with the board, you can eye-ball it or use the straight edge. Connect them to the board about every 8-10" as shown. It is important not to crush the hose much when using the zip ties over it as shown here:
Tools needed:
Drill
Scissors
Marker
Straight edge
CONSTRUCTION:
