meadeam
The barrel adjuster at the bar is turned almost all the way out. I don't like that there are only a few threads left and want to turn out the mid-cable adjuster. I can see the adjuster beside the airbox up against the frame, and I've read various methods of adjusting it by either removing the airbox or not.
I cannot figure out how to remove the airbox and haven't yet found a good manual for doing so. If you've done this before, let me know. Otherwise, I may cut that annoying little clip and see if I can feed the cable up past the frame to adjust it. I'm not sure that clip is necessary, so sacrificing it might be worth not having to remove the airbox. What do you think?
