New set of tires installed so all fine in that department.
As for the place where the work was done, ow boy where do I start! This place looked like a dump. Only picked it based on being the closest partner to me that the tire supplier ships to. But it very much looked like they aren't equipped for motorcycles. This is what I witnessed and I was only there during the replacement work of the front tire.
1. Front of bike lifted with a harness around the handlebars with one section actually squeezing electric wires running under the handlebar.
2. Recently installed wheel tapes clearly disturbed.
3. Scratch on rear wheel I'm quite sure hadn't noticed before.
4. Front brakes dismantled at the calipers instead of at the forks, with the pads falling on a dirty ground, clean greased pin bolts placed on same dirty ground and put straight back in.
5. After installation front tire was not spinning very freely, wonder why!
6. After driving off in pouring rain I discover the rear brake bottoms out with no grip! Resolved after stopping and pumping several times.
I gave up on asking them to try any more with the front wheel spin issue since I could tell their methods are best to stay away from.
So I just got home and did a real quick cleaning of the front brake calipers. Wheel seems to have quite a resistance even when pads are not involved. Couldn't the wheel axle torque cause this if it's over tightened?
With the pads out, front wheel in the air, that tire should
spin at least 5 times when spinning by hand as hard as you can.
They would have moved the caliper pistons so they got pushed in at least a little bit (for clearance removing). Any crap on the pistons would get shoved in. As tight as it is any dirt in there is bad... As for air, I seriously doubt they opened / bleed the system (introduced any air).
You can re-clean them again, but pump(with the brake lever) the pistons out
some, just so you can clean what's dirty.
***Also, Yamaha recommends
brake seal replacement every TWO YEARS. In real life, expect 4-5 years... I changed mine out couple years ago (S2 which has 4 pistons on each side, not 2). I still get about 3.5 full rotations (ft lifted, pads in, pumped up) when spinning by hand as hard as I can...
The rubber seals get hard over time and doesn't like to flex.
As noted above, make sure the floating caliper bracket, where the bolts go in, had fresh grease in it, not old, hardened up grease that will hamper movement.
With your description of the shop / workmanship,
I'd check the CHAIN PLAY per the manual as it it probably too tight.
Should be 2" total, up and down, measured at the tightest point.
