Change done!
Comparison with the old Michelins is not fare
! They were in good condition but really out of date. Initial sensations are very, very,very good. The front is super precise and there is no lean transition strange feelings, it simply goes to the lean angle you choose and stays there. I was comparing it driving with my son (Aprilia RS660 with SportSmart TT) begining with soft rythm and finishing with high in curvy road, no slides on acceleration with the FZ but with the improved grip I found many of the suspension limitations (Front dive, not enough extension damp, etc) and came back to garaje to try solve it
If you consider the tyre as part of the supension unit you have to fine tune it with this in mind and take into account how the new tyre is going to impact In the limits you've got in your front fork and shock. I changed the fork height (from 5mm to 8) to transfer more weight to the front, removed half of the fork oil (Castrol 10) and added Castrol 15 to fulfill the recomended oil heigth to get some more damping retention (Ohlins linear springs but no Golden valve yet). Took away most of the rear shock preload to obtain a balanced front/rear suspension travel, and the magic was done!
The second session was further better !!!
Found that this tyre is very secure in terms of temperature, enough grip from cold to service temp and really grippy when it comes to warm. One of the things I like of this tyre is the ability to maintain the line under heavy acceleration exiting curves, no wideninng at all.
Hope it helps
Cheers
