Fuel pump replacement
pmmcanon
Hi there, I've been restoring my FZ S2 2008 and found the fuel pump is defective. I've tryed an R6 pump to check if this was the only issue and it works so the pump is death. I don't want to change all the assembly because it's too much expensive and all the remaining components work well (the lever, the housing, the o-rings and the connectors).
Do you know any pump engine compatible 100% with the original housing? I'm worried about connectors O-rings and dimensions... Any advice is more than welcome.
To make it more complex the seller has to deliver to Spain (nobody is perfect :D ). Maybe if you provide me with the item code or something similar I can look locally for it.
Thanks in advance
I looked for it in E Bay English and its not there... :( Perhaps as they don't ship to the US??
That does appear to be what is the replacement, it was a Denso...
pmmcanon
Hi again guys, I found a "direct replacement" in Spain, it is an real Nippon Denso pump that hopefully will go direct to the housing and connectors using the original filter. It is the same item reference, with the same specifications so it should work as the original one. When I receive and install it I'll let you know the results and also the part number from Denso if you need it in the future. By the way... 54 Euros is not a bad price
pmmcanon
Done!!! It works perfectly :D . It's a direct and simply straight replacement. Things to take into account: No filter comes with the pump, so you must reuse the existing. There is a small collar where it joins the housing not provided too but you can use the original.
There is no serial/part/item number at any place :rolleyes:, perhaps Denso want to have a parallel market whithout dissapointing the Bikes manufacturers :D.
It comes in a very nice box, sealed and with this plastic card (image attached)
KR from Spain
