fz6 2005 burnt ecu contact
That's not good at all!
What was the error code displayed before it was removed?
I want to say that the TPS signal or the Cylinder 1 & 4 coil output. Guessing its the coil output. Can you tell us what the adjacent wire color is as you may have other issues beyond the ECM.
Ping [MENTION=3172]skooter65[/MENTION] and see if he has one....
I was looking at this before the server went down trying to find a picture I posted about the pin out. But never did find it.
So, what was not working that lead you here to the ECM if no error code was displayed?
Aha! Got it! http://www.600riders.com/forum/fz6-electrical/51657-fz6n-05-error-code-34-a.html
So how does the connector on the harness side look?
The wire color code should be orange with a black tracer. That is defo one of the coil control pins. What about the female end of this? Is this the plug assembly that goes directly to the ECU?
okle001
thanks. the female port is blocked off with the connector it looks like it has been fried but may be able to clean it out.
It seems you now have a Chicken and Egg issue about what caused what.
It appears you found the cause (ECM connection to coil) and have replaced the coils. In my experience, when dealing with high voltage (200, 300v), impurities in a connection can cause the connection to fail. So, something in the contacts between the ECM coil output and the adjacent female connector could have caused the connection to fail and it was an isolated issue. So now its about damage control - i.e. how to repair the harness connector.
FWIW: the ECM output to the coils is roughly 200 to 300 volts but very low current. The coils winding and turns ratio boosts the voltage to roughly 18,000 volts or so. So the quality of that connection at the ECM could have been caused by a simple "bad connection" or impurities.
PS - I think this connector comes apart. That is the orange rubber thing comes out but I never took mine apart so I could be mistaken.
From: http://www.600riders.com/forum/fz6-electrical/50635-need-way-connect-ideas.html
Also, I'm working on a project to by-pass the original ignition output. If you wish to sell the old ECM down the road and have it devoted to science, let me know!
okle001
It was the orange lead that was fried. managed to pull apart and I know sounds dodgy, soldered a sewing needle. I have ridden the bike for about 2hrs with no probs
RONEN
שלום
יש לי קוד שגיאה מישהו יכול לעזור לי
ניתן לפרט במאמר הקודם ..
תודה..
שלום
תודה..
Peace I have an error code can anyone help me Can be detailed in the previous article .. Thanks..
What is the error code?
trepetti
It's all good!
A code 34 indicates an open on the primary (low voltage) side of the 2-3 coil. Not sure the version you have, but looking at the schematic for the US version and there is a red/black wire that delivers 12v to the coil from the red STOP/RUN switch. The other wire is grey/black and it provides ground to the coil from the ECU via the 26 pin connector at the ECU.
Test for:
+12 on the red/black
Ground on the grey/black
Check primary coil resistance (should be 1.53 - 2.07 ohms)
Check continuity of the wires to see if there are any breaks
Check all connectors on the ECU and the coils
Best case is you find a dirty or burnt connector
Worst case is a switching transistor in the ECU has failed
Good luck and please report back
RONEN
Thank you.
Someone a while ago checked my motorcycle and told me to buy coils. And I bought a new one and tested them and they are good ..
The old ones I had were also good except for one .. I just bought but it does not matter ....
I will check the continuity....
