FZ6 lowering fork element - dimensions
tobiaszl
Poland
Hello from Poland.
Few days ago I bought Fz6 from 2005, but due to my height I have to do some lowering.
I found lowering link which is replacement of ending of rear fork.
Because now I can't remove rear shock from bike I am asking if someone have dimensions of this part? For now I know theard M12x1,25.
Ps. Sorry for my English. It isn't really good.
tobiaszl
Poland
Maybe drawing is better name for what I need :) my friend has CNC machine and he can do it for me for free just I need how long it is (or how long is original one) and size of hole for bearings.
If your friend can help;
- take the shock off
- use a spring compressor to remove spring. You have to do this anyways.
- remove the eyelet from the shock shaft
- mill off as much as you can of eyelet.
- you have to leave enough threads to fit the shaft to depth.
- drill and bottom tap eyelet.
- apply loctite to shaft and assemble eyelet to shaft.
- install spring. Install shock.
- Front of bike. Loosen the pinch bolts to allow forks to slide up the clamps an equal amount to level bike out.
- tighten pinch bolts....
Note: the bottom eyelet is known to rust into place. The bolt, needle bearing, sleeve and seals may need replaced.
Good luck!
tobiaszl
Poland
Really great manual! Many thanks! :thumbup:
But probably I will just disassembly my eyelet and: or do totally new on CNC, or I will buy used fork for this experiments.
I
