Fz6s fuel pump
paulfazer600
Cairns
Hi,my problem is with fuel pump on my 2006 fz6s which I removed,disassembled and cleaned. When reassembling there are 2 small plastic pieces that have given others trouble. I have tried to get an exploded diagram of the pump but it was not available. I will try to attach images of the parts and if anyone can help me I will be grateful. Thx Paul 20230329_155728.jpg20230329_155708.jpg
Welcome to our great forum!
This might help.
paulfazer600
Cairns
I was wanting to know how and where these 2 pieces are fitted. When I took the pump apart they fell out so I was not sure of the correct location for reassembling.
paulfazer600
Cairns
This might help.
Thx I will take a look
Hey Paul, On each post, there is a <- reply icon with the word reply you can click on to replay to that specific post. It's on the right hand bottom of the post right next to the like icon. You can also reply to more than one post at a time in your post.
Those parts are probably easy to figure out is they're where the fuel line connects. Take your time and it'll make sense.:)
paulfazer600
Cairns
OK I will have a closer look. Thx for the help.paul
267nk
Brisbane
Hi,my problem is with fuel pump on my 2006 fz6s which I removed,disassembled and cleaned. When reassembling there are 2 small plastic pieces that have given others trouble. I have tried to get an exploded diagram of the pump but it was not available. I will try to attach images of the parts and if anyone can help me I will be grateful. Thx Paul View attachment 75262View attachment 75263
I've not pulled a 06 fz6 fuel module out , but have a 05 YZFR6 fuel module, to replace the pump, filter, & strainer, & For some reason none of the fuel modules have their disassembly secrets disclosed. But 1 thing I do know is that plastic ring with the 4 slots I them, is the ring that slides over the fuel pump outlet pipe , & 1 of those rubbers seals from pump to filter carthridge, but your best bet is to take it to a bike repair shop & try & pry the answer from em.
