yamaha1221
2007 FZ6 Cranks but Won’t Start – Need Help Diagnosing
Hey everyone,
I picked up a 2007 FZ6 from a storage unit, and it’s been a bit of a project. The bike had a ton of wiring issues when I got it—bad splices, corrosion, and random wires everywhere. Since then, I’ve cleaned it up a lot and done the following:
What I’ve replaced/fixed:
What it’s doing now:
I’m wondering if I’m missing something simple—maybe a crank sensor, TPS, or another overlooked sensor? Just want to hear if anyone else has run into something similar. Open to any suggestions at this point.
Thanks in advance!
Hey everyone,
- Replaced the main battery wires
- Rewired the ignition circuit (including to the kill switch)
- Cleaned up and properly wired the starter relay (confirmed one wire to battery +, one to starter motor)
- Replaced the intake air temp sensor (old one read 0°C on d:07, now shows correct temp)
- Verified spark on all cylinders
- Verified fuel pump primes and coils are getting power
- Got the injectors freed up and firing into the cylinders
- ECU powers up and displays codes in diagnostic mode
- It cranks strong, fuel and spark are confirmed, and it seems like it’s almost firing
- But it still won’t fully run
- No immobilizer light flashing, and codes have been cleared (d:62)
- All sensors read correctly now in diagnostic mode
Thanks in advance!
