High idle after using some injector cleaner
fazil
Istanbul
Hello friends, after a long time,
Last week i put some Liqui Moly injector cleaner to my 2005 Fz6 and gone for a pretty long ride like 150km.
Then after coming back home, i realised that idle was a little bit higher than normal. Like 1500Rpm instead of 1300.
I tried to adjust it from idle screw and turned it all the way out, but no respond. Still the same.
May be while making the thtotle body sync. i used all the tolerance of the air screws. I'm not sure about it.
I don't have a sync tool at hand. May be i can try to turn off all the air screws like 1 turn all together to make the idle screw functional again.
What do you think?
Thanks Scott. I did it today.
Now the idle is around 1250 Rpm again after some air screw adjustments.
No syncronization anymore but sounds better.
I made my own tool last year but the height of the hoses were not enough. It looks like they should be at least 1.5- 2 meters to work properly.
May be i can try that again soon..,
By the way, i have a spare throttle body laying around.
May be also i can try to put it on.
Meanwhile i can clean the injectors one by one may be...
Do you use injector cleaner etc?
Greetings....
Well, if it's idling again, I don't see a reason to swap TB's
I'd concentrate more on getting / making a sync tool. You need to get those
adjusted properly.:
As for injection cleaner, I've never had mine out but do use Yamaha's Ring Free additive:
I run this in EVERY gas powered machine I own as well as my customers (small engine repair)
machines.. It does actually work and well worth it in preventive maintenance.
Now my bike is run 365 days a year, I have the idle set for 1,000 RPMs (smoother idle IMO).
I OFTEN see improvement in say 2 stroke weed eaters, highest RPM's I can get-
initially fixed. Let it sit over night, I can tune (with a tach), noticeably more RPMs out of the
engine.
Do you use that injector cleaner regularly or once in a year or so? Do you feel difference in idle Rpm after using it?
I haven't used it for a long time and it affected idle. May be some stuck holes are cleaner now, who knows...
1000Rpm is very nice if it's smooth. I can try to adjust mine to 1000 also next time.
But first i should make a valve adjustment may be. I've never done it.
Bike is like 45k km's and 20 years old. :)
Here's an old video I made for showing charging purposes, but you can see and hear the idle.
18,000 miles with ^^ video. Currently at 38,000 miles and just as smooth running
Ring Free is ALWAYS in the bike (and everything else I own).
You can do a shock treatment with it. Much cheaper than sending them out /
down time, etc, if it works. Again, preventative maintenance.
It took me much digging but for shock treatment, it takes 2 OZ per gallon,
not 1 oz per 10 gallons
I'll do the same about idle after i see this video. :)
By the way, did you ever check valve clearances or change cam chain or tensioner so far?
I have a spare cam chain and tensioner waiting to be installed also.
I checked and adjusted the clearances and found one exhaust valve .001" too tight.
Not much at all out of spec but I was there and figured get it to spec. That was at
26,600 miles(almost exactly). Still has the original chain and tensioner to date (no noises)
