Nate77
Gang... I have dramas
I have LED indicators that I started to fit up today.
I pulled the rear apart and disconnected the existing indicators from my fender eliminate. I run the wiring through the fender eliminator and pinched the new indicators finger tight.
The wiring had previously been joined and added to by previous owner and I had what looked like 2 black wires, there was the faintest grey line on one on later inspection.
Before I'd seen the faint grey stripe I touched the wires on to the wires of the new LED on the right rear, they were obviously reversed so switched them and they flashed fine albeit hyper flash due to needing a new relay.
When I went to test the left side nothing.. the OEM front one wasn't flashing, I tried the right side again, nothing and tried hazard lights, nothing.
Looking at dash there isn't the indicator light showing either.
I've checked the 10A fuse which looked fine. I replaced it with a spare just in case and still nothing. Is it because there's no complete circuit?
I'm a very mechanically dyslexic human but I like to have a go... maybe I just shouldn't ♂️
Any ideas what it might be? Does it sound common? Have I really stuffed something up?
