It seems from what I have read about it. Most of the work comes in when getting it certified by the IBA. Turning in fuel receipts or getting an attendent to be able to vouch for you.
IBA members would yall mind sharing your tips on getting that done. To me it seems like alot of work to get that done and done right?
-bryan
Bryan, it's actually very simple. At the IBA website, there is a form and a gas log you can print out. And the process is this:
1. Fill out the Witness Form with your info, starting odometer reading, and have a witness (two if doing an extreme ride) sign it, verifying the odometer reading. Witness can be a spouse, friend, or neighbor. Witnessing can be done immediately prior to starting the ride, or the night before, if departure time is o'dark thirty.
2. Start the ride by filling the gas tank and saving the receipt, which should show date, time, location (city, state) of the gas station, along with number of gallons pumped. Time stamp on the receipt is the starting time for the ride. Write the odometer reading on the receipt, and number them sequentially to keep them organized.
3. Obtain a correct receipt (as described in #2) each time you stop for gas. Also be sure to get a gas receipt any time your route takes a turn, to "prove the corner." for example, I rode up I-35 to Salina, KS, then went west for 65 miles on I-70. I stopped for gas to get a receipt at that interchange, and then stopped there again on the return leg.
4. At the finish of the ride, obtain the final gas receipt. The date/time stamp on this receipt indicates your completion time.
5. Obtain your ending witness signature on the witness form. This can be done immediately or, if you arrive home at an inconvenient time, get the signature at your earliest convenience.
6. Organize your gas receipts and, using the info on these receipts (odometer reading that you wrote onto them, date, time, location) complete the gas log.
7. Take a map or print out a S&T map showing your route, and highlight or circle the towns where you stopped to get gas. this makes it easier for the validators to confirm your ride.
8. Make photocopies of receipts, log, witness form, map, and mail them along with payment to the IBA.
The hardest thing will be remembering to get the gas receipt, if you're not in the habit of doing so when you pump gas.
So when are you going to do your first SS1000?
:cheer:
