loud_bird
I plan to install new position lights(the ones that pop out of the front fairings). Based on the service manual I have these are normally a 5W load. and i only assume it uses PWM for an always on position lights vs blinking indicators in the headlight assembly? Further I plan to use 100 Ohm 50 watt resistors to get closer to the 5W original expectations. and a diode to ensure proper power flow.
I am unsure how to properly treat the brown and black wiring and additionally if i should wire the load resistor before or after the diode. I've attached a crude diagram of my madness.
