Location of indicators flashing relay fz6n 2007
sensory_tentacles
Australia
Hi all
Sorry I am assuming this has been answered but I can't find an answer for my fz6n '07 Australia.
Is it under the fuel tank? Some pics below. I also took one (the rest tinted one) of boxes relevealed under the left side cowling.
Would LOVE to know what I'll need to install led indicators. I'm tempted to use resistors but would rather save the amps with a new relay instead.
Thank you!!!
Just_Willliam
Ohio
Is there a video of how to install it? Because when I look on my bike at the location of part number 33 there’s a tab of where the rubber mount should be, but it’s not there. Though, there are two wires that aren’t connected to anything that might be where it connects to
Just_Willliam
Ohio
Yo! I found it. Whoever had this bike before me converted it from FZ6 to an FZ6N and shoved all the main cords into the front of the bike in front of the battery box.
I knew the flasher relay couldn’t be anywhere else. It kind of sucked because I had to take off the entire airbox just to remove the battery box, But The flasher relay was shoved underneath the battery box on the right side of the bike. Now all I gotta do is figure out how I’m going to run the cords all the way back to where it should be originally..
Ohendo
Downingtown, PA
Good find. NOTE: It may have not been back in one of the pods originally...depending on the year of your bike. My flasher relay (bike is 2005) is located near the front left turn signal, mounted inside the faring. Yours was probably there also, hence the reason it was shoved where it was when the PO went naked.
