cmdb
Hello all,
I recently bought a 2010 Fazer FZ6 S2 with ABS with 22,000 miles. The ABS doesn't work at the moment, but that's a topic for a different day...
Timeline of events:
There are a few companies who seem to suggest that ECU repair might be an option. I wonder if this is my best bet.
Not sure what would need to be done regarding coding, but I do have the red key. I'm in the UK so the bike has an immobiliser.
Of course, I also don't want to be spending money on bits that won't fix the bike.
Does anyone have any ideas or suggestions? I'm also open to the suggesting of setting the thing on fire at this point!
Thanks in advance
EDIT: December 2024
I replaced the ECU and the problem is now fixed, so the ECU was at fault for sure.
Timeline of events:
- First, I noticed that the bike wouldn't rev past about 10k rpm.
The bike would pull hard to 10k, then the engine light would come on and the bike would lose power, refusing to rev any higher. In fact, as the power reduced, the rpm reduced and the engine light went out again. Then power was restored until I reached 10k rpm again, and the cycle repeated. It felt like a slightly slow, but very aggressive, rev limiter and the EML would flash with each dip in rpm. In neutral, the bike revs to redline and the actual rev limiter. - I figured this was probably spark related, so I bought a service kit, and replaced the spark plugs. This made no difference.
- I checked the bike for codes and it was showing code 34 (Open circuit is detected in the primary lead of the ignition coil (# 2, #3)). I then found that my bike had 2 identical coils fitted, with leads labelled 1,1,4,4, rather than 1,2,3,4 - not sure if this is relevant.
- I figured I'd play it safe and bought 2 used coils with leads etc, off a low mileage bike. Figured I may as well replace the bad coil and pre-emptively replace the good one. These coils were now slightly different, such that the leads were labelled 1,2,3,4.
- Fitted these to the bike and it made no difference. Still getting code 34 and a refusal to rev past 10k.
- I saw someone suggest swapping the coils over to see if the fault moves from cylinders 1/4 to 2/3. I figured there was a very slim chance I'd replaced a bad coil with another bad coil, so I changed them over. Coil 1/4 now sits where coil 2/3 used to sit, and feeds cylinders 2 and 3; and vice versa.
- Bike started and initially ran fine, went for a test ride but about 3 minutes in the engine light came on at around 5k rpm, with associated power loss. This was much lower than normal. The power would come and go for the next few minutes, but ultimately it got to the point where the engine light was on constant, and the bike was running on 2 cylinders. Lots of vibration, very little power.
- Limped it back home and checked the error codes... no error codes reported! Well, under diag 61, it displays 00 (no errors logged) but under diag 62, which shows the number of codes logged, it displays 01. So, it knows it has logged a code but won't tell me what it is. Very weird.
Thanks in advance
EDIT: December 2024
