Naked wire & cable routing
fazil
Istanbul
I am about to finish my naked project with original naked Fz6 headlight.
But i am confused with the wirings and cables.
Do i have to change any route of these wirings from side to side?
Which side the clutch and throttle cables should go?
I use the original headlight bracket also. But i didn't tap 2 extra screw holes.
It looks that it holds with just one on the top. I am not sure though.
Any comments :)
lastlaugh
MD
I rerouted the wires through the hole in the right side of the frame and tucked the connections behind the frame. I had to remove the airbox and battery to get the wires back there and then re-install them after the wiring was tucked. Hope this helps! There is a picture in the naked thread of where my wires are routed.
