newbie with headlight question
oopssorry13
indiana
hello everyone. just bought a 2005 zx6. i understand only 1 dim headlight comes on. but does only 1 bright come on also, or do i have a high beam out? ive read on here about the headlight mod, which i will be doing, but for now im concerned about the basics. lol
I believe the ZX6 has 2 eyes. one for low beam and one for high beam. if you turn on the high beam you should have both eyes lit.
The type of lamp, single or dual filament will determine if you would be able to convert the dual filament for double duty so that both eyes are lit all the time.
JHM
Surrey BC
thank you for the reply.
when i turn on brights, i have 1 dim and 1 bright at the same time
Sounds correct to me. H7 in the left, low only and on all the time. H4 in the right, low not connected (by default) high on with high beam switch.
