Please help identify part
fz6-Dan
Florida
I'm installing the Bd43 headlight mod and while trying to put the rubber piece located beneath the battery back together which I failed to do, this little guy popped up and I can't figure out where to put him back to! I'll try again tomorrow but if anyone has some advice I'd appreciate it!
trepetti
It's all good!
Northern New Joizey
Hmmm. I can't say that I have ever seen that before. I will take a peek when I get home.
Sent from my iPhone using Tapatalk Pro
fz6-Dan
Florida
Sooooooooo I put that part back and put the bike back together. My only problem is the throttle is engaged in neutral at 4K rpm's. I looked online and someone said it may be a leak in the air box or one of the hoses. I check all hoses and they're fine. I'm gonna try taking it all apart and back together. Keep you posted
fz6-Dan
Florida
You simply did the BD43 mod?
And the throttle is completely shutting (cable isn't binding)?
Actually I re and dis assembled it twice to try to fix the problem, the second time I made sure the throttle cable wasn't being pinched and that fixed the high rpm problem, I was a little freaked out at first. So as of right now, all is well!!
