tejkowskit
Gold Member
EDIT 2/19/18: This post has been edited since it's original posting date. There was a problem with the photo hosting site since the date of the original posting. The photos in the update ARE the original photos taken during the original post. The photos taken in portrait for some reason have been rotated to landscape or upside down just as an FYI.
EDIT 4/17/20: Updated links.
This is a how to on adjusting valve clearance. There is already a great thread (which i used up until the adjustment) on how to CHECK clearance by forum member @n0other, but I noticed the forum is lacking a detailed, picture heavy how to on actually adjusting.
I'm just providing guidance and if you screw up your bike following my tutorial I'm not taking responsibility for your mistakes :thumbup: now that we have that cleared up..
Link to how to check (note the picutres no longer show up): https://600riders.com/threads/valve-clearance-check.47593/#post-519725
Things I'll add to the how to check which may save some time & make it easier:
-For fully faired bikes, you will have to remove the inner fairings, but not the whole cowling.
-Removing gas tank fully makes this job easier opposed to just pivoting it back.
-Pay close attention to how the rubber mat is placed over the valve cover. A lot of cables and hoses run through it and it gets tucked into some spots. If you just yank it out you'll have a good time trying to remember how it goes in. Pic of rubber mat I'm talking about:
-Tie the ignition coils, battery cables, and other cables/connectors etc. that sit on the valve cover up to the handle bars to get them all out of the way. Seen here:
-Only turn your timing sprocket clockwise! I know this was mentioned in the how to, but the service manual has a mistake in chapter 3, and I want to clarify.
-Pay attention to how valve cover comes off and how gasket goes. My gasket stuck to the cover, but it could be tricky if you don't remember how it went. When pulling off valve cover you have to twist it a bit to clear it from the frame. Be patient and don't rush. This gasket is reusable so be careful not to damage it.
-Bending the end of your feeler gauges into a hockey stick shape will make taking measurements much easier; especially the exhaust valves. This makes inserting the gauge much easier, and less unnecessary drag is created.
-no0ther reused his gasket on the cover which goes over the timing sprocket, but mine wasn't in as good of shape and was replaced. Clean both mating surface of old gasket as best as possible without scratching them. Mine cleaned up well with just my finger nail. Be patient and take your time doing a good job; you wouldn't want an oil leak. Order parts before doing the check so you aren't left waiting for parts to come in.
-This is a great time to replace spark plugs. Edit: Also a great time to check spark plug caps. See FinalImpact's post below for a link to his tutorial on that.
-Take a lot of pictures so you have something to reference during reassembly. I even do videos so I can listen back to spoken instructions.
On to the tutorial.
Once you do your check (no0ther's guide will get you to this point) and are looking at this:
You are ready to move on.
Pay close attention to the timing sprocket and cam sprockets noting where everything goes when at TDC (top dead center). This is important as everything needs to be in proper order during reassembly. TDC is achieved when cyl. 1 lobes are pointing out. T mark should line up with the line in/on the motor, AND both cam sprockets have markings which should line up with the top of the motor.
T on sprocket and line on motor.
Cam sprockets marking notch which lines up with top of motor. This notch is on both sprockets and they both point out (away from each other)
As you can see in the above picture the exhaust cam sprocket has the 'E' highlighted. You guessed it, the 'I' is highlighted on the intake cam sprocket. Makes putting them in the proper spot easy. I didn't notice any markings on the actual cam shaft, though, so make sure you place those in a manor which you won't get mixed up (or only remove 1 cam shaft at a time).
Right side of motor:
Now you can unscrew the cam sprockets from the cam shafts. There are 4 bolts to unscrew (2 on each sprocket). You'll have to unscrew 1, turn the timing sprocket, and unscrew the other as not all the bolts are exposed. It's not unsafe to turn the timing sprocket without the bolts; the sprockets will just spin freely from the camshafts. Just remember the placement of everything so you can set up your timing properly during reassembly!!
Next is to unwind the CCT (cam chain tensioner). You do not need to remove the CCT. This saves you a gasket and removing the CCT unnecessarily. Unscrew the cap bolt and with a very small screw driver unwind the CCT by turning it clockwise. This takes tension off of the cam chain. (This is a good time to check your CCT. Unwind it by turning clockwise and release it. If it smoothly returns and snaps back it is good. If it doesn't snap back smoothly, well, time for a new one). Once unwound you can hold it in place with a vice grip. You will likely do this multiple times during the job as the visegrips will get bumped or the screw driver will get pushed out. Have patience, take your time..I know it's frustrating.
Unscrew this (manual says to replace washer; mine was in good shape so it was put back into service):
Screwdriver & vise:
After unwound you'll notice all the slack in the timing chain.
Jump to Page 4 for continuation of post!! Continuation found here: https://600riders.com/threads/valve-clearance-adjustment.53398/page-4#post-636712
On to the tutorial.
Screwdriver & vise:
