Various Tiny Freebies
elus1ve
Montreal
If you have at least 5 Rep (Reputation). Pay the shipping and it's yours. The parts are:
- Radiator guard
- Radiator fairings
- Right rear flasher or left front flasher, with the plastic thingy that holds it.
- Left foot peg
- Rizoma bar end black, just one side.
- Headlight bulb mount rubber cover
- Some LED flashers with smoke lens
- OEM levers
- R6 passenger pegs (not pins, springs etc / does not fit the Fz6 without modification)
- Couple of brackets coming from the front fairing. One is to hold the flasher relay.
- Rear red reflectors
- Tail Light cover
- Passenger foot pegs (no pins, springs etc). See pictures in a post below.
They come from a 2007 and most of these I removed after I bought the bike and converted into a naked bike.
Water Bear
Fireball
Georgia
What are those two similar black brackets for? No chance they have anything to do with the front turn signals is there?
Wildcat_drvr
Great-Grandpaw!
Granger, Indiana, U.S.of A.
I could use the levers,
And the LED flashers.
If you please.
Water Bear,the brackets
Go from frame to fairing,
And one holds the flasher relay.
Zip is 46530
Granger Indiana.
Thanks!
:cool:
Rich
elus1ve
Montreal
Provide destination and I will get back to you guys tomorrow. If you already did, then no need to post again as I will PM you. If there are two posts at almost the same time for the same bits then higher reputation gets priority.
Cheers
AlisAquilae
VA
As we discussed over PM yesterday evening:
I'd appreciate the following:
Left foot peg
R6 passenger pegs
LED turn signals
Left front turn signal
Shipped to 48038
Thanks,
Will
