Who can help me still the problem has not been solved for me CODE 33 34
RONEN
is
CODE 33 34
If the coils are good the problem is likely at the ECM or at the pins on the ECM plug. You may need to replace the ECM if the the switching transistors for the coils have failed. Have you confirmed there is power to both coils when the key is turned on?
From Google translate:
אם הסלילים טובים, הבעיה היא ככל הנראה ב- ECM או בסיכות בתקע ECM. ייתכן שיהיה עליך להחליף את ה- ECM אם טרנזיסטורי המיתוג של הסלילים נכשלו. האם אישרת שיש כוח לשני הסלילים כאשר המפתח מופעל?
RONEN
is
At first the garage replaced the coils and returned the problem to me after. I bought from EBAY and also the problem returned
You mean ECU..
When the key is activated I can start but the motorcycle shuts down
Yes, the ECM and ECU are the same. Does the bike start and run on all 4 cylinders and then shut down?
