Hello, the fuel indicator flashes 8 times, then a short pause and flashes again. I've seen older topics about this problem but I can't open some links.
Start by checking the plugs under the fuel tank; look for any wiring issues or corrosion.
Edit: Found this blurb in the owners manual. Obvious, but wanted to include it:
- This fuel meter is equipped with a self-diagnosis system. If the electrical circuit is defective, the display segments will flash.
Check the connectors, check for continuity. Start there.
