Gramwam
Re: Ignition coils
i have the red key...i will look on ebay for a used ECU.
Love my FZ6, she has to live.
Good find! There are 4 hoses that are used for throttle body synchronization. They are normally plugged but unplugged and attached to gauges to synch the throttles bodies. If you have a hole in one you'll want to replace/repair the hose and when you get the bike running again you'll need to do a throttle body synch.Hi Final.
I have just removed my airbox again and noticed a hole in the hose of a throttle body....there are 4 small hoses that are capped at the end. Is this in anyway a factor?
Do you have the address for the company with the ECU's please. I am looking for a new one.Re: Ignition coils
Happy new year all,
It's defo the ECU, have found a company online that provide Virgin ECUs for my bike for @£170.
Have emailed them and just awaiting a reply and even I can take out two Allen key bolts to change it.
Cannot find the throttle sync hose to buy online, may just cut it by the hole and refit it, the damage is right by the connection.
Will update regarding the ecu actually working, thank you again for all the help.
