No work
RONEN
is
Hello The motorcycle did not move and was not moving since. There is a battery starter starter. Can the crankshaft be able to be released. Thanks for the helpers
trepetti
It's all good!
Northern New Joizey
הסתכלתי על ההודעות האחרונות שלך והייתה לך בעיה עם קוד 33 וקוד 34. נראה שקבעת שהבעיה היא בעיה של אקו"ם. האם זו בעיה חדשה, או שעדיין יש לך את אותה הבעיה?
I looked at your last messages and you had a problem with CODE 33 and CODE 34. It looks like you determined the problem was an ECU issue.
Is this a new problem, or are you still having the same problem?
agf
Go Naked- Its liberating
Melbourne Australia
we older members are a diligent bunch, researching our fellow members and translating messages. Language often is confusing as is people's sometimes non-experienced observations. Videos help 100%. We are patient because we want to help and we acknowledge our members come from across the globe- please try to help us help you
RONEN
is
A non-motive motorcycle made a noise. And now finds it difficult to move. Good battery Good starter
trepetti
It's all good!
Northern New Joizey
Who are you calling 'Old'? :)
Thanks Adrian.... well said
trepetti
It's all good!
Northern New Joizey
אנא ספקו פרטים נוספים. כאשר אתה מפעיל את היי, האם התצוגה מופעלת? האם אתה שומע את פריים משאבת הדלק? האם המנוע מתנועע? הקלט סרטון קצר של כל תהליך ההתחלה כדי שנוכל לראות היכן דברים משתבשים.
Please provide more detail.
When you turn the hey, does the display turn on? Do you hear the fuel pump prime? Does the engine crank?
Record a short video of the entire starting process so we can see where things go wrong.
