JONAC
***** Contributor
Acumen Digi Gear - Easy Mod
Hello guys and girls.
Here is my "How to install an Acumen Digi Gear Indicator"
I installed this on my 2007 FZ6 S2 but it is the same wiring for all other recent models. You could easily do this in under an hour. depending on your soldering skills !
Ok.. firstly you will need :
1) Acumen Digi Gear ! :thumbup: Paid about £60 ($120 US) for this including blue alloy housing.
2) Tools for the job:
2 x bungees (to hold tank up)
Drill
Soldering Iron and solder
Stanley Knife (any sharp blade will do)
Pliers or wire cutters
Black insulation tape
A few tie wraps (I only used about 3)
Super Glue
size 4mm and 5mm allen keys
NOW THE INSTALLATION
First of all remove the black panels around the dash. They are held in by 8 bolts. Use the 4mm Allen key for this.
Continued ....
Drill
Super Glue
Continued ....
