Add me to the statistics... Another overtightened oil plug!
Step one is done. Pan and exhaust are off. Just waiting for new parts to roll in.
It feels like its been an age since I've ridden!
Here's some snaps:
Pulling the headers out.
Thanks to Scott (Townsend) and FinalImpact for the tips on lots of penetrating oil. It was way easier than I anticipated.
A few allens on the oil pan were hard to reach but my and my buddy Frankensteined a few items together and made it work.
Boom! Barely got through the first round of beers before we were done!
All in all I hosed the nuts on the header down and let them soak for 30 min or so 3 times before hitting them with the socket. It really wasn't bad at all.
Appreciate all the help on here. This forum rocks!
Any excuse to flash those headers! I'm polishing mine up again for a remembrance weekend in a couple of weeks, two sessions in and they're still nowhere like that.
Op: thanks for the ride along on changing the pan, a good heads up incase I need it one day.
As noted earlier, 12 ft lbs is plenty on that bolt when re-assembling.
If you not comfy with that torque, simply drilling the head of the bolt with a small bit(maybe 1/8" tops).
Then safety wire the bolt for insurance wouldn't hurt. :thumbup:
Now would be a great time to polish up that header!
I started on them! I found your old post and put about 30 min into it. You weren't kidding about elbow grease! I got the mother's chrome polish instead of the mag and aluminum thinking it would be better but all it seems to do is shine and not work any of the junk off.
I guess it's time to man up! :cool:
I found blacksha's post (http://www.600riders.com/forum/garage-mechanical-help/36548-how-replace-your-oil-pan.html) and thought oh man I'm going to have to disassemble half the bike to do this.
At least for a 2007 all you have to pull is the headers to get to the oil pan. 30 min and a little pre soaking with penetrating oil.
Now if I could just fix my broken pride!
Does your torque wrench go low enough for pan install? 12 Nm (1.2 m·kg, 8.7 ft·lb). You need to do it in two steps. Hand snug will do I suspect, then up to final spec.
I had mine off during the header swap from S2 to S1 and a little pan modification. It took about three passes around to stop settling even at those low tq values.
Tips:
Get some Mass Air Flow Sensor cleaner (MAF cleaner) to remove all oil and residue from surfaces. Its better than brake clean
Apply a very thin bead of sealant to outer edge of pan only and outer edge of gasket to engine. You do not want excess going inside and getting into the oil pickup screen or sucked up and plug a passage in the engine.
Toyota, Honda, and General Motors (GM) make great Form A Gasket products.
Clean everything spotless and oil free
IIRC getting the gasket stuck to the block was best.
Fit pan and get the easy bolts started. Get all bolts in and hand snug following CRISS CROSS PATTERN.
Dude, I've had mine two years now and have only just started taking my back wheel off, let alone diving in to the engine. Consider your pride restored!
^^ true dat!!!
Bike has been pretty reliable so the only reason it been apart was for mods!
Wheels, forks, shock, bars, rear sets, triple, Valve clearance adjustment, etc.....
And well this... welding bung to S1 header, build a mid-pipe, remove bump in pan allowing S1 header to S2 chassis.
Don't worry, mine only get done for special occasions. Most of the year they're a horrible shade of brown (think interior decorating in the '70s) with a load of surface rust around the link pipe between 2 and 3.
Man, I've got a oil pan that works 100%... I'd sell you that for less than what they're asking online!
(And, since I've got a 100% intact engine - just about everything else you could need on it)
