- Joined
- Feb 7, 2009
- Messages
- 12,550
- Reaction score
- 1,197
- Points
- 113
- Location
- Cape Coral, Florida, USA
Here's a somewhat long thread on the FJR forum I frequent.
Specifically post #44: Torque loss after service. - Technical/Mechanical Problems - FJRForum
Basically, an FJR was brought in for a valve check, CCT REPLACEMENT (updated version), etc to a dealership.
Apparently the cam chain was NOT ZIP TIED when loose (CCT removed) and jumped a tooth (denied by dealership and
would NOT check / repair it).
Bike would idle, mid range operation OK, NO top end.
Point being, if removing the CCT, pull the side cover and ZIP TIE the Cam Chain
BTW, the FJR and FZ6 cam chain, tensioner, valve check procedure is about identical to each other...
