Code 12
VmvTiti
United States
Hi. The competitive nature of these sites pushes models to continuously improve and put on the best shows for their audience.
Welcome to the forum. When you created the short circuit you may have burned a wire. I would suggest conducting a continuity test of the gray and black wires that go from the CPS back to the ECU. Take note of the condition of the connectors, looking for burnt pins or melted plastic. This would add resistance to the circuit making the ECU see a higher value than the normal range.
If you have good continuity in the harness, your problem may be the ECU itself.
