degake
Stop flashing!! G$*%£#
Nice work there degake! Looks clean and neat!
I ordered a simple bi-xenon hid kit from ebay without the projector, and I wondered how and where exactly did you place the ballast and the ignitor?
Did you remove the airbox? How did you fixed them in place?
If you have more photos please post them in order to get a picture what to expect!
Any tips will be also greatly appreciated!
TIA
I didn't remove the airbox...
I only removed the battery and the starter relay (though the battery shouldn't be removed to route all the wiring).
As for the placing of the ballast:
If you lift your tank, you will see your main wiring harness, which runs from the left side of the frame to the right side (so it goes perpendicular to the "front to rear direction" of the bike )
This will be just next to where the fuel pump connectors will come when you put the tank back down...
I just used some zip ties to keep the ballasts "floating" (so they are zip tied to the main wiring harness) to keep them from rubbing/vibrating against the engine heat isolation (rubber mat).
By doing this, the ballasts are neatly tucked inside the bike, and won't get much water on them
I'll have to look to see if I have any other pictures of where I placed the ballasts
Grtz,
Degake
