AdventAvalon
I was wondering which grips would work for my 06 fz6. I found these and would like to know if they woukd work.Oxford Heaterz Premium Sport Heated Grips - RevZilla
odachi13;597079...but you always worry about killing your battery unless you wire them into the ignition. The new ones turn off after they detect the current change of your ignition off so you don't need to worry if you accidentally leave them on. ... [/QUOTE said:This is a good point. I have wired mine into a power distribution block which is wired to a relay, so it's not an issue for me, but it is something to consider. Would hate to be stranded because you forgot to turn your grips off!
