I am back once again
Bronxman968
Denton
Got the bike running now but after riding it back it goes for about 5-10 mins and then randomly the throttle won’t give any gas. Ride fine when it works but then it’s just no revs yet the bike stays on. First round it shut off was normal, got it to start back up, then the second time I found out my fuel line was disconnected and gas started gushing out. Fixed it and rode it back but it died the same way as the first later on. My guess if maybe the fuel injection line is loose and shuts off for safety maybe? Don’t know though
Is the engine turning off completely (sounds like it's idling, ^^^) but the gauges are still working?
If the engine IS turning off completely, check the RED KILL SWITCH.
Their a known issue, especially if used often.
Polish the contacts with fine sand paper (600g-800g) and clean it with contact cleaner.
If that doesn't do the trick, bypass (place a jumper) in the side stand switch.
