In need of main center bike stand!
SirLanceralot
UT
Just purchased my first bike this past saturday! Anyhow i've got an '05 FZ6, but previous owner did not have the center stand for it. If anyone has the OEM center stand they don't need it would be greatly appreciated!!! Need to be able to tighten rear chain, which is just a little loose and remove the rear wheel in about 1000mi to put on a new tire!
Don't have a CC but in the mean time you can check / adjust W/O the stand.
Find the taughtest spot on the chain and stop the wheel there.
On the side stand, you can check adjust the chain.
It's best if you can "block" between the inner fender and rear wheel (max suspension droop) for the most accurate setting.
SirLanceralot
UT
Got it! Thanks for the info! I'm fairly new to bike maintenance, but I am pretty saavy with car maintenance/repair.
