Lights
bfgb
angmaering u.k.
lights, more specifically side lights. I had one stop working, so I removed the bulb and it had blown. No drama's there just stick a new one in. Best to replace as a pair I thought. When I put the new bulbs in, nothing. Is there a fuse for side lights. Any other ideas?
trepetti
It's all good!
Northern New Joizey
These are the fuses on the bike.....
But are you SURE it's a fuse? Reading above it sounds like you had 1 lamp out, you replaced the pair and now both lamps are out. If there is a blown fuse, it is not the root cause. Since the fuses each protect both left and right for whichever circuit, the original problem was not a fuse problem. So if there is a fuse blown now that both lamps are new, something else is wrong.....
If their the stock FRONT directionals, they do have two contacts (at the base) and only go in one way.
If forced in-correctly, they won't work.
The rear bulbs (directional only) are single contact.
Might want to clarify what bulbs(fronts, or both right side, etc) and check the bulb/install...
