Lithium Battery
fazil
Istanbul
Does anyone use Lithium Battery for our bikes?
It looks like BS brand makes one around $120 (link below)
Advantages and disadvantages?
Any recommendations?
Can i use a regular battery charger or do i have to buy special charger for it?
I use LFP batteries in all 7 of my bikes.
Advantages:
- Light weight
- Holds a starting charge for about over 9 months (only lose 1% charge per month vs 1% per day)
- Over 13VDC static state for faster starts
- LFP is stable with limited ability for thermal runaway.
Disadvantage
- A total discharge renders the battery to useless
- Cost
Be sure to get a battery with a BMS that balances the cells and can turn off the battery before a total discharge (see disadvantage above). Well worth the extra $20-$40.
You don't need a special charger, but if your charger has a desulpherization mode, it must be disabled.
fazil
Istanbul
Gary, thanks for the very useful info.
Do you think BS Lityum batteries have that BMS facility?
What brand of battery are you using?
I use optimate 4 for charging and it has some desulpherization mods i guess.
I am brand agnostic because the internal batteries can be sourced from almost anybody, and that's true for the BMS as well. I try to stay with "name brand" batteries because I hope they are using first run/higher grade cells.
You have to check the battery specs on whether or not it has a BMS (battery management system) with a low-voltage cut-off.
