Post where you found Electrical Parts thread
An interesting bit of info on two batteries that fit our bike. Different models from Yuasa both are lead acid AGM.
Notice: weight, CCA, AH and charge rate differences! Key point being a greater Amp Hr rating 12A/hr vs 10A/hr ends up derating its Cold Crank Amps (CCA) by 15 Amps! Who Knew!
Some info in here: http://www.yuasabatteries.com/pdfs/Yuasa_Specs_Apps_2015.pdf
Battery Type: Yuasa YT12B-BS Replaces stock GT12-B
Battery Family: Maintenance Free
Battery Type: YT12B-BS
Voltage: 12
Capacity: 10 << Amp/hr
Dimensions: 6" x 2.75" x 5.125"
Weight: 7.6 lbs.
Metric Dimensions: 150mm x 69.0mm x 130.0mm
Metric Weight: 3.4 kg
Polarity:
Acid Volume: 0.50
Amps: 1.0 << Charge Rate
C.C.A.: 215
Someone posted this "parts site" on a Yamaha outboard engine forum that has NUMEROUS OEM style connectors for motorcycles.
Included is a sealed R&R connector, headlight bulb connectors, etc...:
Main
Peek thru there, those a bunch of OEM connectors I recognize that are used on our bikes.
rockportcity
US
OR -
Battery Type: Yuasa YTX14-BS
Hi, I just need confirmation on can Yuasa YTX14-BS fit our bike by default ? Or is the any modification need to be made to put a bigger battery on to the original battery box.
Thank u
Thank u
My post is in error. The x14 is wider and taller. Not gonna fit. Editing post.
