Splicing a relay into licence plate light
sensory_tentacles
Australia
Hey guys
Just after a bit of help with relay config
Not sure which prong to attach the splice, fuze box, battery, and ground to.
Also do I just wire negative leads for accessories (say a cigarette lighter) to the frame?
The relay ground is right now attached to the battery but I see most ground to frame to save space. I'll see if I can find a good anchor point.
Thanks!
Darren
so in simple language, 30 is your power in for the auxiliary, 87 is the power out of the auxiliary, 86 will be coming off your "switch"(in your case the the lic plate light) and 85, will be the earth for that.
