Need Help Yamaha Fz6 error 1 code
Toxri
Orašje
Hi i need help on my Yamaha Fz6N 2006 S1
I Have error 1 code and coolant is flashing high temp but i didnt start engine just ignition on, and when i start the engine it work and runs fine with no problem but i got this errors.
What can be?
Welcome to our great forum!
Many times it can be an issue with battery voltage. Check that your connectors to the battery terminals are clean and tight.
If you have a digital volt meter, check your battery voltage during starting and charging. A healthy battery should show 12.8 vdc. while there is nothing using it. You should be above 10 vdc. while cranking to start. you should see above 13.5 vdc. with the engine above 2000 rpm.
Toxri
Orašje
Thanks i will try and hope i will know whats the problem, and solve it, i will post results.
Toxri
Orašje
I resolve the problem, i have problem with the wiers, i rewierd and fix the problem.
For my problem, someone has changed position wiers in the connector.
