Post where you found Electrical Parts thread
Where electrical parts can be found to solve our problems!
TAPA CIRCUIT, INSTANT FUSED POWER SOURCE:
Don't cut up your OEM harness for small accessories. Add this in place of an OEM fuse and power up your Gizmo's!!
Bussman BP/HHH-RP or from NAPA Auto as: 785135, TAPA-CIRCUIT ; Post 17 below for details.
FUSED SOLUTION to Switched Source
TURN SIGNAL HARNESS:
Our good buddies at the2wheels now carry the OEM female turn signal cable found here:
Turn Signals Adapter cable for Yamaha Suzuki x 2 pcs
Turn Signals Adapter cable for Yamaha Suzuki x 2 pcs | eBay
But these won't work for the Front as you need all three wires in the front.
Yamaha 3-wire OEM Connector Pair
Motorcycle OEM Connectors for blinkers and tail lights
MISC HARNESS:
Yamaha pod lamp holder PN 5PW-84312-00-00
HOLDER, SOCKET - Search : 5PW-84312-00-00 (And other Yamaha parts dealers).
H4 and H7 connectors for repair of damaged flags & holder...
Headlight connectors
LEDs:
High Power SMD WLED-xHP5 (194 type) 360 degree Wedge Base bulbs Specifications
LED TURN STALKS:
Edit: I forgot these. . .
the2wheels.com
ELECTRONIC FLASHERS:
Thanks to Cliff for this one! http://www.600riders.com/forum/fz6-electrical/42693-electronic-flasher-relays-great-price.html
LED Flasher Unit LF1-S-FLAT Specifications
Shrink tubing:
3M makes EPS-200 Tubing Adhesive-Lined, 2:1, Flexible, Polyolefin. A 4.0' section 3/8" is $5.00 through Digikey. --> Digi-Key Part Number: EPS2038-ND
EPS-200 3/8" BL48"BX 3M | EPS2038-ND | DigiKey This is good for spark plug wires to return them to OEM protection level.
http://www.corsa-technic.com/category.php?category_id=63
Splice Connectors:
http://www.corsa-technic.com/category.php?category_id=74
FUEL TANK CONNECTOR REPAIR KIT
Compliment of @regder !! Thanks
Home » Shop » Connectors / Harnesses » Sumitomo » HX Sealed Female Terminal for 2 way Sumitomo Honda Injector Connector ( 22 - 20 AWG ) << Sensor
Home » Shop » Connectors / Harnesses » Sumitomo » Sumitomo DL / SL Sealed Series Female terminal 18 - 16 AWG Terminal, loose piece << Fuel pump
Edit: did some more digging, amazing what you can find once you know what you're looking for. It's a Sumitomo connector if you want to search more
Here is the whole connector:
2-Way Receptacle Kit
OEM Connectors for ECU, LAMPS, SENSORS, PLUGINS OF ALL KINDS, plus heat shrink and strain relief.
*** LOOK HERE ***
Corsa-technic.com - Motorcycle Specific Parts!
and the pins:
The Crimp tool need for this repair:
http://www.corsa-technic.com/item.php?item_id=369&category_id=86
EDIT HISTORY:
2015-02-06 Added Tapa Circuit; Amend corsa-technic.com << lots of good OEM connections here!
2014-07-17 Added H4 and H7 connectors...
2014-05-04 added links from www.corsa-technic.com
As the title says, lets make a common thread of where electrical parts can be found to solve our problems.
MISC HARNESS:
LEDs:
LED TURN STALKS:
Edit: I forgot these. . . how could I after all the pain and suffering. . . Perhaps your luck will be better?!
14x LED Turn Signals x 2
Some more harnesses from motodynamics. One is a splitter for the rear signals so you can hook up two. I'm using this to use the integrated tail light as well as the factory stocks.
Another 3 wire hookup so you can put on aftermarket lights without having to cut the factory harnesses. I'll be using these to put on LED stocks when they arrive.
Wire Harness Turn Signal Yamaha R1, R6, R6S, FZ1, FZ6, FZ6R, FZ8 - Motodynamic.com
Not exactly the "Where" to buy, more of the What to buy!
FZ6 Fuel Pumps, Where Used!
20S-13907-00-00, FUEL PUMP COMP
2009, Yamaha , FZ6RYY/FZ6RYCY/FZ6RYCW/FZ6RYW , FUEL TANK , FUEL
2009, Yamaha , FZ6RYB/FZ6RYCL/FZ6RYL/FZ6RYCB , FUEL TANK , FUEL
2011, Yamaha , FZ6R FZ6RAO/FZ6RACO , FUEL TANK , FUEL PUMP COMP.
2011, Yamaha , FZ6R FZ6RAB/FZ6RACB , FUEL TANK , FUEL PUMP COMP.
2012, Yamaha , FZ6R FZ6RBW/FZ6RBCW , FUEL TANK , FUEL PUMP COMP.
2012, Yamaha , FZ6R FZ6RBB/FZ6RBCB , FUEL TANK , FUEL PUMP COMP.
5VX-13907-01-00, 2004-2008, Yamaha, FZ6, FUEL PUMP COMP.
2004 Yamaha FZ600 FUEL TANK FUEL PUMP COMP.
2004 Yamaha FZ600SS FZ6 FUEL TANK FUEL PUMP COMP.
2004 Yamaha FZ600SSC FZ6 FUEL TANK FUEL PUMP COMP.
2005 Yamaha FZ6T FUEL TANK FUEL PUMP COMP.
2005 Yamaha FZ6TC FUEL TANK FUEL PUMP COMP.
2005 Yamaha FZ6ST FZ6 FUEL TANK FUEL PUMP COMP.
2005 Yamaha FZ6STC FZ6 FUEL TANK FUEL PUMP COMP.
2006 Yamaha FZS6V FZ6 FUEL TANK FUEL PUMP COMP.
2006 Yamaha FZS6VC YZ6 FUEL TANK FUEL PUMP COMP.
2008 Yamaha FZ6 FUEL TANK FUEL PUMP COMP.
5VX-13907-02-00, 2009, Yamaha, FUEL
2009 Yamaha FZS6YL/FZS6YB/FZS6YCL/FZS6YCB FUEL TANK FUEL
Correct me if I'm wrong but I think the 5VX-13907-01-00 was replaced by 5VX-13907-02-00.
If anyone is thinking of HIDs there is some fairly inexpensive kits out there. This has name brands all in one place so it gives you an idea. Likely the most beneficial part is the physical dimensions in the 1st link.
Oh - and there are non-HID projectors too if you just want to keep standard halogen bulbs.
Products:
Xenon Projectors - Xenon Design Creations
Compare:
HiDplanet : The Official Automotive Lighting Forum - Bi-Xenon Output Comparison: TL, E55, Murano, FX, IS, e46,LR3
Other sources:
HID Projectors from The Retrofit Source Inc
Awesome find for making repairs or electrical mods;
Self Sealing Heat Shrink Tubing - aka w/ Adhesive GLUE INSIDE!!!
Manufacturer: NTE
Product: Dual Wall Polyolefin w/Glue Adhesive
Shrink Ratio: 3:1
Temp Rating: 125C
Sample PN: 47-23348-BK = 3/8"
Sample PN: 47-23148-BK = 3/16"
HOWEVER; If you need a real flexible repair, the Dual Wall is Stiff and MAY create strain on the wires where it exits! This could be an advantage in some applications. It is a very robust product. Google the PNs for a supplier near you (Mouser, Newwark, Allied, even Amazon carry this PN!).
Added info to first post: FUEL TANK CONNECTOR REPAIR KIT
Tag: Lifted fuel tank, pulled the wires apart, broken pins, damaged wires, repair wires.
Before you molest your bike (or cage) cutting and hacking the OEM harness, keep this little product in mind!
It a circuit tap that piggy backs off the OEM FUSE holder! You just pull out the OEM FUSE, insert this, install the OEM fuse into it on the side closest to the insertion point.
You now have a spare tap without wire damage like a Scotch Lock cutting strands of wire.
YOU MUST BE WISE about loading; the spine or back of the fuse panel can only handle so much so don't piggy back a 35Amp fuse. But for little accessories, this it perfect.
$8.00 is way better than chopping up the OEM harness. In my case I need a fused and switched source that comes on with the key to operate the fuel controller. Hopefully this fits under the cover!
F/I
PN: NAPA 785135, TAPA-CIRCUIT
56048d1423281108-post-where-you-found-electrical-parts-thread-img_20150206_192719_035-jpg
Its gonna power this mess!
56049d1423281108-post-where-you-found-electrical-parts-thread-img_20150206_193221_488-jpg
Edit: this worked perfect. Yes using power from the brake light cicuit, notice the OEM wire in to the fuse is larger than the one out to the light. The cover won't close but I'm OK with that. The pod cover fits with room to spare.
56107d1423471986-08-fz6-condensed-build-thread-final-impact-img_20150208_170736_142-jpg
Post up some more details.... Not sure which ones you need.
One of the links in the first post has a bunch of OEM connectors...
PM your way...
