Mr_Green
My front sprocket is stuck pretty bad. Tried standing on the broken chain while the bike was in gear and it kept moving on me. The bolt seems pretty rusted. Not sure what to do.
Thanks
Thanks
It always makes sense to start trouble shooting where you left off. Make sure that the new sprocket is fully engaged on the splines of the output shaft, that the nut is torqued to spec, and that the washer in bent-over the nut. Also, make sure that you have the chain slack to spec @ =/- 1-inch (50mm).
"taking too long to get up to speed" could be a symptom of a worn clutch. Does the engine increase in rpm, yet the bike fails to accelerate proportionally?
What do you mean by "has trouble when idling"? What trouble does it present?
Why do you suspect the fuel filter? Do you have rust issues in the tank?
