What brake pads do you use?
trepetti
It's all good!
Northern New Joizey
I am about to replace the pads in my 05 FZ6, and I want to make sure that I make a wise choice. Currently leaning towards EBC HH Sintered, simply because I know EBC and understand sintering. What I would REALLY like is objective input from real riders.
So tell me, what pads do you use and what do you think are the pros and cons?
Thanks
Jayson
BC, Canada
Anything name brand should be good.
I have always run the EBC HH on the street and liked them very much. On the race track I find that the SBS Carbon give the best power and feel, but wear far too quickly. The EBC Extremes have slightly less initial bite, but last 5 times longer than the SBS.
PhotoAl
Birmingham, AL
Im also looking for a new set of brakes. Used EBC HH Sintered on my Ninja 250 and was happy with them. Current pads have 36,000 miles on them and have been experiencing some shuddering at low speeds while turning and braking. Couple of days ago was turning off the street into the parking deck at work and had a good bit of shudder, nothing scary and was not trying to brake real hard. The front tire does have some uneven wear (cupping) which may be the cause. Thinking it may be time to do something about the brake pads.
QwickFliCk
Manly Man Member
NY
ive been running the ebc HH for 16k miles and i think it needs replacing real soon :thumbup:
Cali rider
Well-Known Member
Buena Park, California
Attention:thread-jack begins here!
Oh boy, I am really go off on this topic!
Since the 15000 mile mark I have had this same intermittent shaking/chatter under similar conditions. I have chased it in so many ways that it has become an obsession to cure it some day. At this point in time I have made the following checks/changes to try and solve the problem:
- R6 fork mod. I have manipulated oil viscosity/level, ride height, fork tube position, rebound and compression damping and full rebuild of ALL internal wearing components. None of these changes has cured the shaking problem.
- R6 front calipers as part of the R6 fork mod. Changed from EBC HH pads back to stock Yamaha pads, rebuilt both calipers, rebuilt master cylinder, replaced lever pivot screw, changed brake fluid multiple times. No specific effect on the shaking problem either way.
- Front wheel. Pulled rotors and checked runout of the front wheel axial and radial, and checked the runout of the rotor mounting surfaces. Absolutely nothing out of specs. Looked carefully for any cracks or debris that might cause this problem, nothing found. As a point of mental comfort I changed the wheel bearing and seals. Rebalanced the wheel after all was reassembled. All of this effort resulted in no change at all.
- Steering assembly. Although I had replaced the stock steering bearings at about 20000 miles I disassembled and inspected again at 80000. Found that the tapered bearings had worn a set of indentations at the forward position. New bearings, full inspection of all of the clamps looking for any sign of fatigue or cracks. Reset everything, no effect on the chatter problem.
- Frame inspection. Looked for any sign of distortion or bending, nothing. Checked the torque value of all six T-50 Torx screws that hold the two halves of the frame together in the steering stem area. A couple of these moved a bit to reach full torque but not what I would classify as "loose". I then supported the weight of the motor with a jack and loosened all of the motor mounting screws. I did see that two of the motor mounting points did not want to align exactly on mark so I used so line-up pins to get everything in place without stress before I proceeded to re-torque in the correct sequence. After all of this effort-no change. Again. This is getting quite frustrating!
- Body work. Looked everywhere to see if something loose or displaced my be having a effect, but of course nothing was found.
- Rear end. I have the Ohlins shock setup, and it's dialed in nicely so that isn't the cause as I had the chatter before I made the suspension change. Checked wheel alignment many times using the string method (everytime I replace the rear tire), that's not the problem.
- Front brake rotors. I have replaced them TWICE, most recently with the 5VX-2581T-01-00 revision rotors. All three sets of rotors have always measured less than .004" axial runout both on the fixed carrier and the floating rotor. Replaced the anchor screws once. Currently this seems to have stopped the shaking. I went for a very aggressive 350 mile ride Monday, really pushing the limits of the bike and trying to induce the chatter. Only happened twice the entire day, but both times were heavy braking while changing direction.
- Tires. I have had the chatter with several types of tires, and pressure/temp vector seems to be the only variable that has any useful feedback value. I am going to do another ride Friday to test some pressure changes as I mounted fresh tires today as my ride the other day just cooked my Bridgestone BT-023 tires, though they were getting near the end.
There might be something else I have checked and haven't mentioned so I might add to this thread later. My opinion is that rivets that secure the rotor to the carrier wear over time allowing the rotors to move in a RADIAL motion as you apply brake pressure. It doesn't happen everytime I stop, but it has happened at speeds between 5 and 120 MPH. When it occurs it causes my front wheel/handle bars to shake from side to side/like a tank slapper would be. I can usually bring it back into control by slightly modulating brake pressure down then back up. But it has caused me to lose control once while downhill braking and turning that I just could not bring back to normal, forcing me to run wide into the opposite lane. Scared the **** out of me as the front wheel would not turn or stop and it had been fine for the previous 100 miles of that particular ride. Needless to say I want to cure this problem for good and share the results with everyone else for reference.
I will update in a couple of days.
Sorry for the threadjack help but....:rolleyes:
I had the same thing with my front brakes(FZ6). Checked rotors for run out, bled the brakes, lubed the rivets then cleaned the rotors with acetone and scuffed them. I replaced the brake pads with EBC (breaking the inner and outer radius for quick bedding) and it seemed to help the problem but was still there slightly,eventually fading away to nothing.
My idea is that with all the nano technology we have with so many products today it's easy to see a rotor become contaminated. Any oil, even from your hands can do it....
We now return you to your regularly scheduled thread.... :p
FB400
Long Island, NY
I like the EBC FA199 organic pads for the front. They have better bite than the stock pads and are very gentle on the rotors
fb40dash5
NoMD
Same here, though I haven't tried sanding the rotors yet. It doesn't really bother me all that much... definitely not enough to throw 4 rotors, some pads, MC/caliper rebuild kits, etc. at it! Mine was there pretty bad with OEM forks/brakes/pads, and got a lot less severe and less frequent with the R6 fork/brake swap and new pads.
Galfer ceramics for me, I forget the compound number but I think it's 15-something? I'm thrilled with them aside from the chatter thing, but that doesn't sound like I can blame the pads from what I see here!
rsw81
Keep it Kosher
Boston, MA
John has clearly been eating his Wheaties this morning!
To the OP: I just switched to EBC HH and am really liking them. Good initial bite, easy to modulate, seem to be wearing well. A lot of riders I know use them and like them, which is why I decided to give them a try. Not too expensive either.
regder
Toronnto
I'm on my second set of EBC HH front pads. They work well with good initial bite. I got about 55k km on the first set. They are harsher on the rotors than OEM so keep that in mind.
If they were priced the same, I'd probably get OEM as I was pretty happy with them. The EBC's were half the price though
asp125
Denver
I know this thread is pretty old. Everything on this forum says EBC HH sintered pads are the best upgrade for better bite. I have a new-to-me FZ6S2 and yes the front brakes feel wooden. Wondering in the years since these replies if there have been any other pads that give increased bite and feedback - Galfer? etc?
gnyce
north of Philadelphia PA, US
for me - IIRC, the biggest change for me wasn't the brake pads but instead, installing braided/stainless steel brake lines. I put CRG adjustable levers too, so the initial bite takes very little pull. Beyond that, if you want _more_ you'd need to look into a brake caliper upgrade, IMO.
trepetti
It's all good!
Northern New Joizey
^^ Lines and levers make a BIG difference. As for pads, I have used only the EBC HH for many years and never had an issue. I didn't test any others, and the HH's are pretty pricy, but they work great.
trepetti
It's all good!
Northern New Joizey
I LOVE the CRG's. I had previously used cheap Chinese levers. They were crap.
asp125
Denver
Update - Replaced the OEM with a set of HH sintered pads this weekend and a significant improvement in bite and braking feel.
