MichaelFZ6
Hello everybody from frozen Russia! And pardon my english skills, they are getting worse each time I write here.
I want to install short grip on throttle, so I can twist my hand on lower angle and get full throttle (attachment 2). One guy in our community recently made such mod with a grip from R6 and pretty satisfied with results. I tried to google similar cases but found nothing. So I have some questions that I hope you can answer!
1. One idea is to buy this tube https://www.motionpro.com/product/01-0094 , I found one in stock in russian shop. The thing is, I only found one example of it's usage on different bike. So far it is the best option for me. I dont have dimensions of the disc, where the throttle cables are installed, therefore I cant compare. In attachment there is a grip from R6 with such diameter. Does anybody have experience with this tube?
2. Second plan is to use basically any throttle grip from any damaged bike. I need to get throttle disc diameter ~40mm , cables play as shown in attachment and grip length similar to mine. I tried to ask at one big shop, described the situation, the said "we have many grips, come and measure yourself". Have anyone installed grip from another bike to fz6? I live in a small town, so I will have to google grips dimensions for each case and hope it will fit.
3. Buy grip from totalled R6 as this guy in our community done. The easiest way, though for some reason I cant find such grip.
4. Cant find anything good on aliexpress. All grips which I found have diameter of ~32 mm, which is low.
So what should I do? Motion pro tube is long ago discontinued, I messaged russian shop for some dimensions of the tube. Tried searching this forum, cant find anything about throttle grip.
