There is some info to be gleaned here. . . A bunch of links (see below). Some in detail others not so much. THANK "OhioYJ" from R6-forum.
http://www.r6-forum.com/forums/showthread.php?t=142421
Section I - Fuel Controllers
- Why do I need a fuel controller
- How they work
- Do I need a fuel controller
- PCV vs. Bazzaz
- Other options
- My Two Cents
- FlashTune Interface vs PCV / Bazzaz
Section II - Maps
- Choosing a Map
- PCV Maps
- PCV Maps with AutoTune Tables
- PCIII Maps
- Bazzaz Maps
- FlashTune Maps
Section III - Exhaust 06+
- Exhaust Basics 06+
- Midpipes
- Headers
- Headers vs Midpipes
- EXUP
- Smog Block Offs
- EXUP Explained
Section IV - PCV and Software
- Calibrating Throttle Position
- Enabling AutoTune
- Setting Target AFR Tables (Also applies to Bazzaz)
- Firmware Updating
- Separate Maps for each Gear
Section V - PCV AutoTune
- Why AutoTune changes never stop
- When to accept trims
- Using trims as suggestions
- Troubleshooting
Section VI - FlashTune Flash Interface
- Warning
- Factory ECM Limitations
- FlashTune Software
- Using / Installing the Device
- Troubleshooting / Connection Issues
Section VII - Installs
- Smog Block Off Plate Install
- Header Install
- PCV Install
- New Grips
- Repacking a 06+ R6 GYTR slip-on
Section VIII - R6 Maintenance
- dIAG Mode
- Diagnostic Codes
- Fault Codes
- Maintenance Schedule
- Adjusting the TPS
Section IX - Sprockets and Chains
- Sprocket / Ratio Changes
- Chain / Replacement Size
- Rivet Links
- 520 vs 525 vs 530
- Sprocket Material
- Wear / Maintenance
- Speedometer Correction
__________________
- How they work
- PCV vs. Bazzaz
- Other options
- My Two Cents
Section II - Maps
- Choosing a Map
- PCV Maps
- PCIII Maps
- Bazzaz Maps
- FlashTune Maps
- Midpipes
- Headers
- EXUP
- Smog Block Offs
- EXUP Explained
- Enabling AutoTune
- Firmware Updating
- Troubleshooting
- Warning
- Header Install
- PCV Install
- New Grips
- dIAG Mode
- Diagnostic Codes
- Fault Codes
- Adjusting the TPS
- Rivet Links
- 520 vs 525 vs 530
- Sprocket Material
__________________
