pester
pester
Mine broke and can not find one online...anyone knows where to find one?
Sent from my SM-N900W8 using Tapatalk
So I bought a set of used original signals and an R&G tail tidy which was the ONLY eliminator that I could find that was designed to take the original signal stalks.
R&G Racing Fender Eliminator Yamaha FZ6 2004-2008 - RevZilla
I bought my bike used and one of the two POs had replaced the fender with one of those that comes with small LED signal stalks. They were small and not bright. I wanted the more visible stock signals but most of the eliminators only have a small round mounting hole that will not work with the egg shaped rubber stalks of the stock signals.
It's a bit pricey but it works great. Get the license plate adjusters unless you want to drill holes in your plate. R&G is from England and they use a different size of plate.This mounts closer to the rear edge of the tail light so there is less likelihood that you'll cause the plate to meet the tire.
Good Luck!
Did your eliminator work with the stock signals and their rubber mounts?
