chiefbawskee
Hey yall, I have spent the last 2 days scouring the internet trying to figure out what is wrong with my bike (05 YZ6 with 33000 miles). Yesterday, I installed an IDEA gear indicator and some LED strip lights (to make me more noticable at night). After install and everything working correctly, I went to go take it for a test ride and put the gear indicator to learning mode so it can learn the gears. I quickly learned that my bike would not rev past 2000 rpms like and would immediately shut off like the kill switch was hit. I am a mechanic and very well versed in engine building and design and have built several race cars. I have a full range of tools from a Fluke to everything in between.
things that i have tried and tested:
Any help would be greatly appreciated!
- verified that the kick stand kill switch works
- verified that the handle kill switch works
- checked codes: there are none
- checked gas tank and gas (half a tank of gas and no debris inside)
- verified TPS works (16-100)
- checked stored codes (CPS and Tip sensor- all work as per specs)
- Checked CPS (299 ohms- in spec)
- adjusted idle to 1200 rpms
- new battery
- verified all fuses are good
- checked oil level (good)
