grcamna7
Premium Member
I'm considering installing,as one choice,a D.i.D. 530VX3 drive chain because others said it's a good one,although it's a good bit wider than my stock OEM 50V4 DiD chain..
The link pins/chain width of the D.i.D. 530VX3 measures 25.3mm
My stock Yamaha DiD 50V4 chain measures 24mm pin width.
I love the quality of the OEM Yamaha DiD 50V4 chain and there is one available through Partzilla,although it's an endless chain,and I'd rather not have to remove the swingarm;I can't find a DiD 50V4 master link for it.
I want to stay with 530 chain,not 525.
Edit:I may reconsider removing the swingarm pivot bolt and lower shock mount,to see if I can tip the swingarm over enough to get a new endless OEM DiD #50V4 Yamaha #94582-11118-00 drive chain over it;hoping that's all that's required,plus I can also grease the swingarm pivot bearings while I'm in there.
I'm looking around online for the(Partzilla is asking $167)best deal for an endless stock chain.
